does anyone make a 2 inch lowering spring that goes in without mod??
can i use 2000 wrx sway bars on front and back?
1991 ss lowering springs
Read though this post which has been "stickied" at the top of the page in the Suspension section of the forum due to it's vast amount of reference on what will fit from the various Subaru models.
http://bbs.legacycentral.org/viewtopic.php?t=2153
Jason
It's at least a starter's guide to suspension info. Why don't you assist in updating it Jamal?
Jason
Idk how old you are, but you need to read and write properly. Rarly will MODIFICATIONS bolt in with no alteration. That's why they are called modifications. If you did some searching, to figure out the exact year and model of spring and strut you might want to use, and posted that information here asking for advice as to MAKING it fit on your car, you would get more help.
You mean an actual MY2000 WRX. Like from japan? I think the front one will, But I think you would need the lateral links as well as the swaybars and mounts.
Peace
-Adam
Peace
-Adam
Kickin' it old-school.
I did happen to have just made a swaybar faq explaining what fits, what doesn't, and why.
Anyway, a GC wrx front swaybar will fit a turbo legacy. An 02-07 WRX wagon front bar will also fit a turbo legacy. Probably. Turbo and non-turbo front swaybars are not interchangeable. Impreza rear bars do not fit on any Legacy because of the spare tire well. STi rear swaybars don't interchange with anything else because they are wider.
