noisy lifters? try this
jefferson
Post by jefferson »
Got a tip from subychris94 the other day that he kind of stumbled on and it has worked for me everytime as it has for him. Thought I would pass it along.
If you start your engine and your lifters are making a racket, shut your engine off and then restart it. End of racket. Can't say for sure why it works, but it does. Try it.
Jeff
douglas vincent
Post by douglas vincent »
This trick has worked for me for the past 4-5 years!
smh0101
Post by smh0101 »
OR... If you are NA... You could have the rocker arms swapped out from a '97 2.2L...
NO more Lifters!!! All solid!!!
We had it done to my FWD and it works great. Dale at Northwest Subaru service suggested it!
Post by 555BCTurbo »
smh0101 wrote:OR... If you are NA... You could have the rocker arms swapped out from a '97 2.2L...
They will work on Turbos...
Rocker geometry is the same
smh0101
Post by smh0101 »
Kool!
I havent had any lifter issues with the turbos... only that NA...
