CUSTOM GRILLE/ FOG LIGHTS/ SIGNAL LIGHTS
1991legacyturbo
here they are, i moved the existing signals into the side driving lights and moved some fog lights in to the existing signals. i made the blacked out debadged grille with some mesh from work(and fibreglass ) and bondo)
Arctic Assassian
1991legacyturbo
Arctic Assassian
Looks awesome. Great work. If Vikash (VRG3) sees this he'll probably tell you that the light beam put out by the turn signals isn't sufficient. So while this may work for now, you might even consider investing in some JDM Legacy corner lamps...
1991legacyturbo
