Ok guys...I could REALLY use your help this time!!!!
Snow-Attack
Post by Snow-Attack »
ok 1990 legacy wagon 2.2L MT 4WD coming down the back side of a hill after passing somebody got up to around 95 and was back to like 80 when i just lost all my power so i look at the tach and its bouncing back and forth from 1000-2000rpm for about 30 seconds than it just dies completly!!!! I check for fuel and the pump is still working. im not sure about spark and it cranks like it has plenty of vlttae so i dont think its the alternatior.
just as a side note im not sure if its an old code or a new one but it has code 13 which i believe is the crank angle sensor....my front cam oil seals have been leaking for awhile so i was wonder what your guys thoughts were on the oil shorting that sensor out??? just a rndom thought
But any Help would be awesome since im 50 miles from home with a broke car :(
Ben
1994 subaru legacy
MI winter package heated seats,mirrors,dark grey interior,5MT 202k,wrx 16" wheels
1992 Touring Wagon LE
td04 turbo,wrx tmic,tinted windows,sti pink struts,lowering springs,16" wheels,wrx brakes,remote start,keyless entry,alarm
Maybe your timing belt skipped a tooth or a bunch atleast. Seems like often instant failure is usually that. Could even be bad fuel yet VERY rare.
Snow-Attack
oh and i did check the timing belt and it is not broken just as an fyi
1994 subaru legacy
Still could have skipped a tooth though.
The tensioner could have failed, causing the skip. Happened to me once when I stopped for gas.
speedoboy31
Post by speedoboy31 »
check the crank bolt. you may have the good old sheared keyway if its loose.
Saskatoon Subaru
Post by Saskatoon Subaru »
speedoboy31 wrote:check the crank bolt. you may have the good old sheared keyway if its loose.
that happened to me last summer, i'm currently in the middle of a rebuild to get replace the crankshaft.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
BXSS
Post by BXSS »
My obdII Impreza will not run f the cam pos sensor is not plugged in.
I'd think the leggy would not run or run badly with a bad crank pos sensor.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
