So the last thing I gotta do is bolt my flex plate back up to the torque converter. But, the TC bolt holes arent lined up with the access window.
Any way to rotate the TC so it will line up?
Rotating Torqueconverter to line up with flex plate??/
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
1986 Toyota 4Runner
You should be able to spin it just by sticking a screw driver in the access hole on top. if you have the starter out you can grab the teeth on it and move it easier. it should be really free though and easy to move. I left mine lined up with one of the bolt tabs located at the access holes and then after getting the first bolt in i put a wrench on the master pully and rotated the crank to the next bolt.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
might want to keep a magnetic pickup tool on the bolt as you screw it in from the top. they can fall in there and be a pain to get out.
an offset 12mm wrench with a magnet stuck to the other end might be a good idea too
Air-to-Water Intercooler, VF-39, 550 injectors, AEM FIC, stainless race header, 3" stainless exhaust, 75hp Nitrous, 150psi H2O injection, intake mods, stock: long block, 4EAT, ecm.
I was able to bump the starter to get the threaded insert to line up with the access hole. Then I carefully threaded each bolt in by hand, and was able to use my wratchet to snug them up good'ntight.
Was kinda a pain, but not as bad as trying to re-install the intake manifold with the engine in the car
1986 Toyota 4Runner
1986 Toyota 4Runner
