Legacy rear diff internals in a WRX case...
Alright, have a bit of a 'situation.' A friend of mine has a WRX with a 3.9 STi 6mt. He needs a 3.9 rear. I have the stock rear diff out of my '92 SS. He would like to be able to use his thicker WRX axles though. My question is can the internals from a '92 SS rear diff be put inside the case of a WRX rear diff such that he could use his stock rear axles?
Anybody have a PDF or tips on backlash settings in the LSD?
I swapped the LSD carrier into a new diff housing and needed to swap the companion flange as well. As a result, I had to take the pinion nut off.
With the correct flange back on, I got the nut right back to where it was before on the shaft, but I wouldn't mind checking the backlash while I have the unit out.
Maybe I'll just have a look at the contact pattern using grease on the ring gear, and call it good if the pattern is all in the center and not biased to heel or toe.
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
