instaling crankshaft key
Posted: Thu Mar 06, 2008 1:52 am
by Saskatoon Subaru
so i've got my engine back together, and i'm trying to put in the on my crankshaft, now should it just slid in or do i have to force it some how?
Posted: Thu Mar 06, 2008 3:41 am
by Boostedballs
If you are talking about the timing gear and key- I would heat up the gear a little bit to make it 'larger' and it should go on without too much beating. If you do have to beat it on, use a deadblow hammer or a piece of wood to lighten the blow. Also, I would use some thread locker on the whole thing since these things have a tendency to wobble loose and tear up the crank.
Posted: Thu Mar 06, 2008 1:27 pm
by Saskatoon Subaru
im not worried about the crankshaft gear. the key that goes into the end of the crank, its not just sliding into place and im not sure if i should bead on it to get it into place.
Posted: Thu Mar 06, 2008 8:12 pm
Try cleaning out the key hole, and heating the end of the crank with a torch. You could even try putting the key in the freezer.
Posted: Fri Mar 07, 2008 1:33 am
by Saskatoon Subaru
Legacy777 wrote:Try cleaning out the key hole, and heating the end of the crank with a torch. You could even try putting the key in the freezer.
thanks worked like a charm.
Posted: Fri Mar 07, 2008 7:21 pm
Glad to hear it worked. Sometimes the simplest things work well
