GL or GX or JX
awssubaruls
GL or GX or JX
Post by awssubaruls »
sir,
kindlly inform me is it possiable to fit all elctronics spear part and seonsors from (1.8,2.2) & (GX,GL,JX) on legayc 92 wagon (SL)
thanks
legacy europe model LS 92
400.000 Miles
No probably not.
awssubaruls
ok sir what about
1-tps
2-oxygen sensor
3-IAC sensor
thanks.
400.000 Miles
What year are the GX,GL,JX ?
Are these legacy models? I'm unfamilar with them.
In the US, the GL is a 1980's vintage subaru, and none of it's electronics would swap over to a legacy.
awssubaruls
yes sir its
400.000 Miles
Compare your sensors to the sensors of the cars you are pulling them from.
If they are legacy models, then the chances are better that they would work, but as mentioned, I'm familar with those models.
Like Eric mentioned, compare the sensors, if they look to be the same, they probably would work.
