GL or GX or JX
Posted: Fri Mar 07, 2008 8:09 pm
by awssubaruls
sir,
kindlly inform me is it possiable to fit all elctronics spear part and seonsors from (1.8,2.2) & (GX,GL,JX) on legayc 92 wagon (SL)
thanks
Posted: Fri Mar 07, 2008 8:18 pm
No probably not.
Posted: Fri Mar 07, 2008 8:24 pm
by awssubaruls
ok sir what about
1-tps
2-oxygen sensor
3-IAC sensor
thanks.
Posted: Fri Mar 07, 2008 8:44 pm
What year are the GX,GL,JX ?
Are these legacy models? I'm unfamilar with them.
In the US, the GL is a 1980's vintage subaru, and none of it's electronics would swap over to a legacy.
Posted: Fri Mar 07, 2008 8:51 pm
by awssubaruls
yes sir its
Posted: Fri Mar 07, 2008 8:56 pm
by ericem
Compare your sensors to the sensors of the cars you are pulling them from.
Posted: Fri Mar 07, 2008 8:59 pm
If they are legacy models, then the chances are better that they would work, but as mentioned, I'm familar with those models.
Like Eric mentioned, compare the sensors, if they look to be the same, they probably would work.
