I am looking for an abs pump for a 91-94 Legacy, let me know what you got!
I would also be interested in everything needed to swap over from abs to a standard braking system if nobody has an abs pump.
thanks!
WTB: ABS Module/Pump
Tim
93 Legacy SS Winestone 5mt swapped
Megan Racing Bellmouth 13psi
WRX Intercooler and Hoodscoop
JDM ej20G DOHC head swap, wiseco pistons and td04 in the making.
I have at least two of the different styles...let me know if you still need one.
FYI: I removed the pump in my race car when the engine was out, I think it might be hard to do with the engine in the car. I picked up all the lines (you just need the ones in the engine bay and master cylinder from a base model legacy and swapped everything over with a proportioning valve from a same vintage Impreza RA with the same brakes but no ABS. The lines and master cylinder were all plug and play, the proportioning did not work correctly, it biased the fronts too much, I ended up going back to the legacy unit and it worked perfect.
