Fender flares for wider/offset tires
Im looking for fender flares for my 1993 wagon for the purpose of putting wider tires/offset rims on for off road purposes.
The tires I want will stick out on the sides thus the needed flares.
Anyone know of any flares that will fit onto a legacy wagon really nice or what the closest you can get is ?
Sheet metal. Cut out the small flares there and replace them with wider ones, 22B-style.
+1 pics would be nice
was the tool like this? Wherehow did you procure it?
The interwebz tell me that these are not cheap. I know some larger chain stores will lend some tools like spring compressors. Maybe only body shops have rollers?
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
yes that's what I used. It's easy and that tool works really well. We did a group fender rolling and install day thing. It's generally something like $50 for a week rental and there's a $250 deposit. I just pitched in $10 for the rental. Performance wheel and tire shops sometimes have them.
You can't really tell the fenders are rolled unless you look closely. But they are rolled and pulled out over 1/2" on all four corners.
I'd say it's most noticeable at the back of the front fenders because you can see them angle outward from the door.
I'll try to get some decent pictures tomorrow. The ones I took with my cell-phone don't show anything.
this is funny cause last night i was thinking about if i had the money i would make fiberglass and carbon fiber fenders and also make widebody fenders and things like that but i have not won the lottery yet.
you would have to get creative with the flares when you put them on the back wheels because of the door being so close to the wheel arch.Suba-Ken wrote:How about using a set of black, rubber/urethane flares from, let's say a Nissan pickup, and bolt them on? The'll give a clean finished look and hide all sorts of rust spots underneath. Thoughts?
if the purpose was to fit really wide tires for a track car i would think it would look pretty good. function over form and all that.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
