turbo legacy transmission- needs new synchros $150.00
high mileage turbo legacy tranny (came out of a wrecked car so still works good to my knowledge) $300.00
turbo legacy tranny case and center diff- i blew up the gearset but the case and center diff is still good $75.00
turbo legacy tranny- i broke something in this tranny, it no longer goes into 1st gear, but all the other gears work fine- $100.00
Almost brand new exedy WRX clutch- OEM replacement clutch (pressure plate/disc/throwout bearing) i was running in my legacy but i put the 6 speed in it along with the 6 speed clutch. only has about 7k on it, still looks brand new. $200.00
JDM Twin turbo motor- i bought it to swap the heads into a turbo legacy but i'm going a different route with the car now, the driver side cover is broken but the belt and everything is still intact- $500.00
JDM EJ20(K?) heads/ manifold from a 97-98 WRX- complete intake/ heads/ cams/ sprockets/ covers $500.00
WRX style center diff casing- brand new, make an offer
3" catback exhaust system that came off of my 1990 turbo legacy must have a WRX downpipe to use (works with stock WRX downpipes and catless Downpipes)- $300.00
jdm 89-90 legacy turbo foglights- $100.00
97 Legacy GT rims- good condition, light curbage SOLD
i will ship at the buyers expense!!!
i will post pictures of everything tonight. all parts in tacoma, wa
