boost solenoid
94legacyturboawd
boost solenoid
Post by 94legacyturboawd »
do you know what problems would occur if this was faulty? My car cuts off when the boost kicks in, and solenoid clicks continuously when key is in acc position, and for about 5-10 seconds after I turn the car off. the fans also come on when I turn the key to acc even when the car is cold when I accelerate, the car seems to cut off around 3000 rpm, if I stay under the car runs fine. also the motor will rev way above 3000 when I am in neutral, like there is nothing wrong.
silver 94 turbo ss need lower control arm
01 maxima daily beater
95 ford contour trans blown
Sounds like you have the green check connectors connected. Disconnect them.
