WRX TR seats f and r
What would the fitment of these seats be in my '91 Legacy SS? Are they going to fit, would the position be ok as far as height and knee room, seatbelt mods of some sort? Any other issues?
http://memimage.cardomain.net/member_im ... 9_full.jpg
http://memimage.cardomain.net/member_im ... 2_full.jpg
Thanks, team, for your input. John.
Canadian Turbo
I put 03 WRX front seats in my SS a month ago.
They fit. However;
-They will bolt into the exsisting holes with the exception of the rear inside bolt. This last bolt will line up perfectly with where the seat belts are bolted down. So you will need remove your existing seat belt bucle and bolt the seat in it's place.
-My seats didn't come with the seat belt bucle, but I'm told they were incompatible anyway. So the Extra long bucle looks rediculous sticking up from it's new home (bolted to the seat itself) but they work. I'll find a solution to this someday.
-The seats DEFINETLY sit higher (this is a source of debate in other threads) Luckily the driver side seat has good height adjustability. I'm 5 foot 9 and I have to recline the seat a little more than I'd like when I'm wearing my helmet. The pasenger seat does not height adjust however, and my 5'6" copilot/girlfriend hates that she has to sit so far back with her helmet on. I'd say it's 2 inches higher.
Width wise, they touch various places arround the edges, but this has no ill effect as far as I can see.
Knee room seems fine.
As far as the rears go IMHO forget about it!!! Too much trouble. Maybe someone else has had a better experience.
But the asking price seems very fair even if you don't take the rear.
Over all, IMO for the price, a nessisary Legacy turbo mod.
They fit. However;
-------Jonathan--------
livestrong14
Yep, they all bolt in.
The only issue I had putting in my 01' RS seats was the fact that the rear seat was out of a coupe. Still looks perfect, just has a small 2" gap near the fuel tank tunnel, can't even be seen unless looking for it.
They do sit higher, I compared it to having the stock seat height adjustment lever all the way up top.
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
I just put the seat all the way up and sat in the car. My head brushes the headliner a little. Not sure I like that. I'll have to drive like that and see how I like it. Don't want to hit my head when going over a bump. Maybe as I get older, my spine will compress and my body will be shorter! I'm just under 6' now.
I have not looked , but can you cut a section out of the rails and reweld them together to get lower?
kleinkid wrote: I have not looked , but can you cut a section out of the rails and reweld them together to get lower?
I believe that is doable...
If you are ever down this way...stop by and I will help ya with that!
tris91ricer
- Title Whore
Trevor still rocks the WRX backseats in his '94 wagon. We claim it to be the only one in the world that has 'em, too.
*shrug* So far I haven't seen or heard of anyone else having WRX backseats (with the dope headrests) in their wagons.
If you're looking for decent bolsterage and a lower seat, I suggest custom bracketing a pair of FC3S seats. (that's circa 89-Whatever-ones-came-before-the-kind-torretto-drives) I had them in grey, for a time, and besides the bad welding/bracket-modetry, I liked 'em. High-back cloth seats, great bolstering, comfortable, rode LOWER than stock seats AND on top of that, leaving PLENTY of underseat storage space- they weighed approximately 5lbs less than Turbo seats. They even matched my interior. But like I said, the bracket-modetry sucked, so I took 'em out.
I don't mean to divert you, but if you're looking for a better seat, I'd hunt down a set of FC seats -- they might be the compromise you're looking for.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
got '05 WRX black F and R
To get those TR seats from California to Washington would have cost $380 UPS, $500 moving company, $800 freight shipped. Not practical.
Instead I locally bought all black fronts and rear '05 WRX, from a 12k mi. car. They look very nice.
Canadian Turbo
Shoot, sorry!! I looked at the ones I bought with my seats and then looked at the back of my SS and whent NO WAY. Maybe the guy gave me the wrong seats??555BCTurbo wrote:Canadian Turbo wrote:
They bolt in
Do it PLEASE, I'd really like mine to be lower. It'd be nice to have my co-pilot sitting like Nicky Grist in the pic on the home page. I was planning on trying my hand at it, but your pointers would certainly reasure me.n2x4 wrote:Lowering the seat rails is doable. I've done it to mine. I just cut the brackets so that the rails were flush with the floor and rewelded them on. It got the seats back to stock hight, maybe a little bit lower.
I've been meaning to make a how to with some pics...
modify to lower
n2X4--Write up with pics would be greatly appreciated.
Good to hear it John. To me those TR seats look very hard to keep clean and to match with door cards...
Yes, pics when you have them.
having a problemo
Right now there is a installation problem. The inboard mounting bracket does not match up with the stock location. When you line up the outboard bracket with the holes in the floorboard, the inboard bracket is about 3" to far forward to match up with the holes. These are '05 WRX seats. Need to eat some tacos, and then do some searching on here to see if I can figure this out. Any ideas, team?
I don't know about model years but when I installed my Recaros with the generic WRX bracket it didn't look like the holes lined up until I got the front two cranked down and the inside (drive shaft tunnel) rear torqued down. THEN the outside rear lined up. So I'd work front to back. I think I tried back to front and had alignment troubles. Also, you won't use BOTH tunnel holes one will need be abandoned but you'll see which one. Put the bolt back to keep water out...Good luck!
Geezus. No way! I feel for you man. Time to visit your friendly neighborhood welder...Or could you swap out the rails and lower 'box" for the old leggy ones???
Or you could buy the generic Recaro rails and have the darn thing lowered an 1" from the get go...Might want to give Speedware a call in the morning and pump them for info...
http://www.speedwaremotorsports.com/ind ... =CONTACTUS
Then order the WRX recaro brackets online?
This just wierds me out - really??? I just can't believe it... Take a quick picture and post???
w/pics
Front seats--the inboard bracket is bolted down front and rear. Here are some pics that show the position of the outboard bracket. Arrow points to bolt hole.
It looks like some cut, and reweld is going to be required. I want it lower also. Positioin is kind of high with the seat in the lowest position.
Is the outboard slide tied to the inboard?
Looks like you can release the slider using the normal means and grab the outboard slider to move it into place. The bolt holes should align if it can be moved up seperate from the other one.
John,
Yeah you need to pull up on the slider handle, and push/pull the bracket to the correct location.
Whew! Yeah, that's it! Should slide up. There's no cross piece boxing these out and that one got pushed back...
