Well i was on the way to put the banjo bolt back on (block to oil feed line) and notice that there are metal shavings on my bolt.
Next i look in the hole and the first 4-5 threads are gone.
Then i look at the bolt and its all intact.
I also notice that there are still 6-8 threads that the bolt didn't touch(reason for question 1)
Now questions:
1) How long is this Banjo Bolt supose to be?
2) can i get a longer one to use these 6-8 threads?
close up
i think i can get a longer bolt what do you think?
1998 Legacy GT-T ... sold
If there is room in the head you might be able to tap the hole deeper and make a longer custom bolt. Or if there is enough meat in the casting you might be able to tap it bigger and install a sleeve. Whatever you do its gonna be tricky to keep the shavings out of the oil. Some pictures would help, and I'll try and remember to look at my stock heads to see what the options might be.
Gary
asc_up wrote:Yeah, while you're tapping it I'd try to find a way to place a magnet as close to it as possible.
That way it'll attract most of the metal shavings to it.
Unfortunatly that trick doesn't work on aluminum. Greasing the drill and tap will help some. If you do the best you can to keep the shavings contained, you can crank the engine with the hole open to flush out the remaining chips. Makes a mess though.
If so, that part of the head comes off (note the 4 bolts). You could find a replacement or at the very least remove it to make the repair without getting chips in the oil system. I haven't taken a close look at the part, but from the looks of it in the picture I dont think tapping it deeper or bigger is going to be an opiton. But I bet somebody on the board could make you a good deal on one off an old/bad head.
Gary
That IS the same peice that All Talk was trying to show you. It's a bolt on to the back of the head.
BlackBart FTW!
Yeah, just remove that piece from the head, take it to a machine shop to have a Heli-coil put into it...mine was the same way...I just put the bolt back in and torqued it reeeeal gently.
The longer bolt might work fine, but make sure it’s not too long, if it bottoms out in threads it won’t seal and when you try and snug it up to make it stop leaking it will pull the rest of the threads out. Also, make sure the sealing faces on the fitting and bolt are good and use new sealing washers so that it will seal with minimal pressure. If you have to really wrench it down you will likely pull what’s left of the threads. I say try it (I would), if it doesn’t work then you will have to go the long way around.
Good luck.
They put that many threads there for a reason. Only using 6-8 aluminum threads may not be enough to hold the 80+psi of oil pressure that is seen right there (I have my oil pressure gauge there, and that through five feet of -3 line).
Just take the thing off and get it heli-coiled or buy a different one from someone on here. Seriously, its only two o-rings that seal it to the actual head. Cripes, I have one if not two extras laying around, and I could find you 4231345 more by the end of the night. Everybody have Tleg heads laying around. If you want one, PM me.
93forestpearl wrote:They put that many threads there for a reason. Only using 6-8 aluminum threads may not be enough to hold the 80+psi of oil pressure that is seen right there.
well the bolt was only using the 4-5 threads since those were the ones that were stripped
