Does anyone know the conversion from mpa to lbs. The boost gauge in the wrx set I installed reads in mpa and I was wondering how that compared to pounds.
Jeff
boost calculations?
boost calculations?
Thanks guys. I am going to boost her up on the way to work tomorrow and see where I am at. I put that conversion site in my favorites.
Jeff
Jeff
I believe Vikash has his numbers off.Arctic Assassian wrote:umm... kilopascals and megapascals are the same? because thats what you just said.
1 kilo= 14.5psi
1/2 mega= ~7psi
1 kPa = 0.145 psi
0.5 MPa = 72.5 psi
Sorry, I did have my numbers off. I haven't studied this stuff since 1997. Thanks for the corrections.
Josh's numbers are right.
100 kilopascals, or 0.1 megapascals, is about atmospheric pressure.
So 0.05 MPa is about 7 psi.
I checked my gauge and it has .05 and .1 marked on the face. It's good to know what I am seeing now. Thanks again.
Jeff
Jeff
