ok so i think this is the right place to put this question
between 2500 and 3000 rpm along with the awesome whine from the turbo i hear a steady clicking sound, it almost sounds like a loose heat shield or something.
it sounds like its coming from the turboish area perhaps slightly lower. the heat shields are not loose and there is nothing in that area that i imagine could be making this sound. could it be a broken blade in the turbo?
i'm hitting just below 9 psi with everything stock right now so its working well. i find it weird how it only happens in the beginning of the boosting period when psi's are still low. and it only happens under load, in neutral there isn't any noise. any ideas?
-Alex
turbo click?
turbo click?
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
wow really? i would have never thought.
luckily this weekend im installing my intercooler and my manual boost controler. so once i unhook the boost solenoid and put the mbc in its place it should stop the noise right?
or do i have to completely take it out of the entire system?
thanks lots
alex
thanks lots
alex
depends...mexicanzero wrote:wow really? i would have never thought.
thanks lots
alex
is your MBC a bleed type or "normal" ?
for my MBC i removed all hoses from the stock boost control solenoid.
i did a thread, search it up. might help
if you could hear the stock solenoid click over the sound of the turbo and the motor going 3k under load then you have the greatest hearing EVER.
