Need Fast Clutch help
Posted: Mon Apr 07, 2008 7:21 pm
by simbey1982
looking at replacing the friction disk in my 2.2l turbo with pull type clutch. Is the friction disc on those the same as the push type?? what about a newer WRX friction disk? Nobody sells just the friction disk and for a kit when you add the word turbo, the price doubles so if the friction disk was the same i could buy a cheaper kit....they look the same to me....
Cory
Posted: Mon Apr 07, 2008 9:12 pm
by PhyrraM
Not sure if the disc is the same, I would guess it is not.
You cannot use a WRX one unless you also switch the pressure plate to a WRX one. It's 3mm(?) bigger.
Posted: Thu Apr 10, 2008 3:06 pm
by GLCraigGT
I think the dealers will sell clutch components individually. It wouldn't hurt to make a couple of phone calls.
Posted: Thu Apr 10, 2008 9:45 pm
by asc_up
Click It
This is where I bought my clutch kit. I'll stand by them religiously lol. It was a great deal and an awesome product!!
Any clutch and clutch kit for a WRX (not STi) and I believe the 2.5RS (not sure if it's hydraulic like ours) will work.
Posted: Thu Apr 10, 2008 9:54 pm
by PhyrraM
+1 for Gripforce.
Any non-turbo (including 2.5RS) will NOT work. (as a kit)
Posted: Thu Apr 10, 2008 10:14 pm
by asc_up
I thought the 2.5RS had a hydraulic clutch like the Legacy SS. Is that not correct?
Posted: Thu Apr 10, 2008 10:44 pm
by PhyrraM
It is hydraulic, yes.
Turbo 5 speeds have a pressure plate that gets pulled away from the engine to disengage.
Non-turbo 5 speeds have a traditional pressure plate that gets pushed towards the engine to disengage.
The flywheels, pressure plates, throw out bearings, transmission castings, and most likely the clutch discs are all different between the two.
Posted: Thu Apr 10, 2008 10:47 pm
by asc_up
Oh ok. I was under the impression that since it was hydraulic, it was also a pull type clutch.
Thanks for clearing that up!!
