Need Fast Clutch help
simbey1982
Post by simbey1982 »
looking at replacing the friction disk in my 2.2l turbo with pull type clutch. Is the friction disc on those the same as the push type?? what about a newer WRX friction disk? Nobody sells just the friction disk and for a kit when you add the word turbo, the price doubles so if the friction disk was the same i could buy a cheaper kit....they look the same to me....
Cory
PhyrraM
Post by PhyrraM »
Not sure if the disc is the same, I would guess it is not.
You cannot use a WRX one unless you also switch the pressure plate to a WRX one. It's 3mm(?) bigger.
GLCraigGT
Post by GLCraigGT »
I think the dealers will sell clutch components individually. It wouldn't hurt to make a couple of phone calls.
There are three kinds of people in the world, those who can count and those who can't.
2009 STI, It's staying stock, well at least the first 100K
84 GL Wagon With Factory Brushgaurd, The Lack of Power Wagon RallyX machine.
asc_up
Post by asc_up »
Click It
This is where I bought my clutch kit. I'll stand by them religiously lol. It was a great deal and an awesome product!!
Any clutch and clutch kit for a WRX (not STi) and I believe the 2.5RS (not sure if it's hydraulic like ours) will work.
PhyrraM
Post by PhyrraM »
+1 for Gripforce.
Any non-turbo (including 2.5RS) will NOT work. (as a kit)
asc_up
Post by asc_up »
I thought the 2.5RS had a hydraulic clutch like the Legacy SS. Is that not correct?
PhyrraM
Post by PhyrraM »
It is hydraulic, yes.
Turbo 5 speeds have a pressure plate that gets pulled away from the engine to disengage.
Non-turbo 5 speeds have a traditional pressure plate that gets pushed towards the engine to disengage.
The flywheels, pressure plates, throw out bearings, transmission castings, and most likely the clutch discs are all different between the two.
asc_up
Post by asc_up »
Oh ok. I was under the impression that since it was hydraulic, it was also a pull type clutch.
Thanks for clearing that up!!
