front wheel to awd
the_watts10
front wheel to awd
Post by the_watts10 »
i recently bought a front wheel drive legacy and was wondering what is necessary to switch it to awd i have a automatic awd tranny dont know if these parts will help?
ej22t hybrid, 3.5" downpipe, Gl turbo intake/desnorkel 9psi DEAD
Murphy
Post by Murphy »
the AWD tranny is a start, but you need a lot more.
auto drivshaft, rear end, axles, complete rear suspension, AWD gas tank, rear crossmember.
i think that is it. all of the parts should be bolt in, i dont think any real modification is needed.
does you AWD transmission have the TCU with it? is your FWD auto?
1990 Legacy LS, 4EAT
Arctic Assassian
Post by Arctic Assassian »
parts don't bolt in.
The FWD cars did not star life out as AWD cars, the AWD cars start life out as FWD cars.
You have to drill and tap some stuff.
Kickin' it old-school.
PhyrraM
Post by PhyrraM »
http://bbs.legacycentral.org/viewtopic.php?t=18370
I would only reccomend an AWD swap if your going 5 speed. The AWD autos have more wiring and a different TCU than FWD.
Post by 555BCTurbo »
Arctic Assassian wrote:parts don't bolt in.
You do?
Like what?
No you don't!
Every single bolt hole is there to do the swap.
the_watts10
lets see i have one awd auto thats in my car right now
and i have one fwd manual thats in my other car
so i have awd rear end and crossmembers but whats the problem with the starter location?
PhyrraM
Post by PhyrraM »
Later cars (not sure of exact year) use 6 bolts between the engine and transmission. Early cars use only 4.
If you use a 6 bolt trans on a 4 bolt engine you are missing the second (lower) bolt that holds the starter. There are a few ways around this, but I have never done it. So I'll leave it to others to comment.
Arctic Assassian
No you don't!
I only say this from limited experience. I once had a 93 impreza FWD. I wanted to make it awd, but when I put it in the air, I didn't find holes for the carrier bearing. After seeing that, I said forget about it.
the_watts10 wrote:lets see i have one awd auto thats in my car right now
If you have a vehicle from the mid 90's you shouldn't have to worry about the starter bolt location.
Arctic Assassian wrote:I only say this from limited experience. I once had a 93 impreza FWD. I wanted to make it awd, but when I put it in the air, I didn't find holes for the carrier bearing. After seeing that, I said forget about it.
They should be there. There's covers that go in the bolt holes, and over time they blend in, plus undercoating tends to hide things.
I'd be rather surprised if they weren't there.
the_watts10
so as long as i have mid 90's cars then nothing besides the starter will interfere cause i have two 94's and what is the gearing on a wrx tranny?
Arctic Assassian
It must have been the undercoating.
the_watts10 wrote:so as long as i have mid 90's cars then nothing besides the starter will interfere cause i have two 94's and what is the gearing on a wrx tranny?
Final drive is 3.90, however there is a 1.1:1 stepper in the rear gear reduction.
I'd have to check on the individual ratios if that's what you wanted.
