Auto Tranny Filter
93Subadan
Auto Tranny Filter
Post by 93Subadan »
Looking at doing an ATF drain and refill in a couple months and picked up a filter for dirt cheap. I searched through my Haines manual and there is nothing in there about replacing this filter, does anyone know how it's done?
My best guess is that it is located in the pan that holds all the ATF. It also looks like there is just a gasket that seals that pan or maybe a liquid and gasket mix like the oil pan. Are there any other gaskets, o-rings, or seals that I might need? I'd hate to get it apart and not be able to put it back together without leaking like a sieve ;-)
Saskatoon Subaru
Post by Saskatoon Subaru »
theres a gasket for the pan, a o-ring for the filer
take the pan off and i believe there's 3 or 4 bolts that hold the filter, and there's 1 bolt holding a electrical connector and 2 bolts holding a pipe that have to be removed in order to the the filter out.
i just did this cause my tranny was having a fit,its not hard, its a fairly simple repair.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
There is an external add-on filter on the frame rail near the battery. This is still more a screen type filter.
There is an internal screen filter as well inside the transmission.
C. Scott
Post by C. Scott »
Picking up on an old thread.
I have a question about my auto tranny.
92 L
211K
The cars runs good (a little hestitation now and then on take off), but in the winter (southeast Texas ;-) ) it takes 3 to 5 seconds before the transmission engages from P to D. Once it's warmed up, it's fine. No other shifting problems are noticed.
Now the questions:
Changing fluid is obvious, but should I change the filters too? Should I replace both tranny filters or just one? If just one, which?
Thanks in advance,
Chris
You can back rinse the internal trans screen. The external one I wouldn't worry about.
The issue you're experiencing is due to a check valve that is allowing the torque converter to drain. I'm not exactly sure where this valve is....but it's relatively common unfortunately.
Where in SE texas are you?
C. Scott
Post by C. Scott »
Josh,
Thanks for the reply. Looks like I'll do a TransX and a fluid change.
We've actually corresponded before. Last year I think. I live in Pearland.
Regards,
Chris
Ahh ok.
Yeah I seem to recall it now. My memory seems to be fading :)
Buffman
Post by Buffman »
is there a part number available for the external filter. with as much grime on it, it's probably never been changed, and I plan on changing it.
1992 Legacy LS Special Wagon..
There's a part # for the filter add-on kit. Replacing just the filter actually costs more then the kit.
Part # is 31099AA091
BTW, this thread has a lot of part #'s in it,
http://bbs.legacycentral.org/viewtopic.php?t=631
Not to mention I posted the parts catalog in the stuff you need to know forum as well.
Buffman
Post by Buffman »
thanks legacy777. Called the dealer today and they wanted $77 for the filter! No to mention $43 for a wiper arm, and $28 (not bad) for the lift handle. I found an online subie parts dealer (is there one recommended to use?) but still not much of a discount. Not like my Buick. I can get Delco parts for pretty much 1/2 off the dealer list price...
www.subarugenuineparts.com
Go to the online catalog and type in the part #. That's the cheapest place I have found, and have been dealing with Jamie who runs the internet parts for many years.
Buffman
Post by Buffman »
Ahh $14 for the Filter Kit. A lot better price :)
