Auto trans question
Auto trans question
My 93 legacy ss is auto, we just finished swapping in a 1.8 bottom end, now driving it around the trans feels a little soft, shifting wise and seems to keep the revs up a bit. there should be the appropriate amount of fluid in the but when you pull the dipstick out its covered a good inch or 2 above the full line, any ideas?
You should check the fluid level with the trans at normal operating temp (hot). Drive the car around, park on a flat surface. With the engine still running, slowly cycle through the gear selector from park to 1 and back to park. Leave the engine running, and check the ATF level.
