So I installed a Chris Paiano FCD (VRG3's design) and was running with 14 PSI. Everything was working great and then I got a CEL as I launched onto an onramp.
I pulled the codes and I have:
17: 4th Fuel Injector Inopperative
21: Faulty Water Temp. Sensor
45: Atmospheric Pressure Sensor Faulty
Everything is connected correctly; I'm positive on that. So any ideas on what's up?
FCD Issues
FCD Issues
Wow never mind. I must be partially retarded.
My boost gauge stopped working when all that happened and I didn't even think about that being the problem. I went out and checked and I guess 14.5 blew off the crappy plastic T. So I bought a brass one and everything is fine now. Even the FCD
Sorry for the n00b post everyone
