So, two years later I Decided the wagon was too slow and found a 95 impreza 1.8 to trade up to. I get my first loan, my Dad says and I quote: "I knew I should have stayed home with you more," still not letting the truck thing go... 4 days later I am driving on an off camber hill and smash into a pole and am without my new car for 46 days, but who is counting.
Long story short I wanted more power and happened upon this message board. I find this crazy obession with the legacy SS and documentation about swaps was becoming readily available. I happen on a 94 SS 5mt in a junkyard with no hood or front fenders and a large dent in the rear.
BOught SS for $400 and started to gut it immediately. Performed my first swap IN 8 months time, sans wiring. I swapped over everything ss I could engine, tranny, brakes, suspension and with the Help of Rallitek
This time I set goals before I started:
RELIABLE ~250whp
Low end torque
Good handling on pavement but great on gravel and snow
Light weight
To not bug Matt Monson so much that he kills me
I started building the engine which as of now sits at:
ENGINE
EJ22t Block
Ej25D Twin Cam Heads Ported, Ceramic coated chambers and Ex. Ports
Custome JE Pistons 8.5:1 CR Ceramic crowns/Moly SIdes
Brian Crower Connecting Rods
STI 11mm Oil pump (from 08STi)
STI Waterpump
STI oilcooler
STI OIlpan
EJ20H Intake mainiflod. Ported and Powerder Coated WHite
Ported Throttle body
STI Timing Belt
TUrbo
IHI VF37 From v8 STI
Ported Polished and ceramic coated.
STI Twinscroll Headers also ceramic coated
2 1/2" with cat back at the bumper (just like the rally guys)
Drivetrain
Legacy SS 5mt Transmission
Hydraulic Clutch COnversion
OBX Helical front Limited Slip Differential
STI Group N motor and Transmission mounts
Prototype Kartboy Rear Diff Bushings (thanks Tom and TIC)
Cobb "Rally" Short throw shifter
Exedy Lightweight Fly wheel
STI CLutch Pressure plate and disc
Custom Stainless Clutch
Kartboy shifter bushings (all)
