ECU swap
smh0101
ECU swap
Post by smh0101 »
So, would it be possible, to say swap the ECU into a Sport Sedan from like a v3 STi?
I'll be running STi Heads (20k) and was thinking, ya know... that has to be better than the Stock SS ECU and standalones are spendy.
What would that entail? Would I need to re-do the wiring and stuff or would it just swap in?
Thoughts?
Post by 555BCTurbo »
A ton of wiring...especially because the V3 is, I believe, OBD2...
BXSS
Post by BXSS »
V3 & V4 ECUs are OBDI, but are physically different than V1-2 (+SS) ECUs in that they have 3 plugs instead of 4 so the plugs will have to be cut/ removed & connected to the correct pin on the V3 ECU (alot of wiring).
If you look @ the pin-out for a V1-2 WRX & compare it to a SS pinout you'll see the wiring is almost exactly the same so these would be a more plug & play solution to a OEM ECU upgrade.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
PhyrraM
Post by PhyrraM »
For the V1 and V2, or even the BC/BF Ej20G, go look in the "Electronics help, PFC into EJ22t" thread. Most of the details on how to get it done are in there.
