Legacy Mesh Wheels
Legacy Mesh Wheels
so i found a set of Legacy MEsh or snowflakes or whatever you want to call them 16X6.5 IIRC. they have 205/55/16. From everything ive searched it seems that this is a hit and miss size tire for different years in regards to rubbing. I have a 94 with stock struts and suspension. Can anyone confirm that these will work without rubbing?
1994 SS 4EAT Aegean Blue Metallic
I'm Running 205-50-16s on The Angel with absolutely no Problem. your tire would be a touch taller than mine but the same width so shouldn't be a problem.
[img][img]http://i110.photobucket.com/albums/n88/ ... 050007.jpg[/img][/img]
