Repairing Curb Rash
93Subadan
Repairing Curb Rash
Post by 93Subadan »
I picked up some 16" tires today for really cheap, but they have a bunch of curb rash and I'm wondering if there is a good way to repair it. They are aluminum alloy and I'm planning on painting them a copper color (would look great with the winestone car) so I'm wondering if bondo would work? Any other suggestions?
Cheers!
ciper
Post by ciper »
My ghetto way was to dremel the entire thing down evenly then paint them :)
There are companies that specialize in fixing curb rash. How do they do it?
I've wondered the same thing. Could they weld a bead around it carefully and grind it back down after?
Bondo might work temporarily. If the environment didn't remove it, tire changing would.
Post by SubaruNation »
jb weld,
and..
this url will tell you the rest...
i just dont know what page it's on.
i know it's not on the 1st 4 or 23
http://forums.nasioc.com/forums/showthr ... els&page=4
"For repairing wheels, I used the toothpaste tube of Bondo and it worked great but I heard good things about Aluminox so I started using that. That stuff is strong!! Once it dries, you can sand, paint and even drill it! It's mostly used to repair holes boats so it's strong stuff. A little harder to work with than Bondo but it's good stuff.
Aluminox
Image "
from Nasioc
