For Sale: JDM Forester Red Intake Manifold
livestrong14
Hey guys,
I am selling a JDM forester high-rise manifold. Works with 20G heads. It was coated with a high heat red wrinkle finish. Works with all IAC's and stock 22T sensors.
Only asking $125
Let me know,
-Devan
Only asking $125
Let me know,
-Devan
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Arctic Assassian
Arctic Assassian
Arctic Assassian wrote:Is it because the 90 inlet won't clear?
Correcto...In fact...I think it may also not clear the compressor housing...the EJ20G intake manifold has a significantly different runner design...
Arctic Assassian
Arctic Assassian wrote:What about straight inlet turbos like the vf39? could you run an under manifold inlet with this?
I looked into it and I don't think there is enough clearance with the fuel lines there...
Arctic Assassian
If you go under the intake mani, how do you work with the power steering?
Arctic Assassian
You should be able to use a straight inlet turbo (td04, VF23, VF22, vf39) with this manifold/fuel lines & the coolant bridge from a under manifold inlet motor (ej20H/R....).
You'll also need a ps-pump from a under manifold turbo inlet car for everything to "bolt on".
If you can't get the coolant bridge or fuel lines I'd just do the parallel fuel line mod & run the fuel lines on top of the manifold.
OR
You if you were going to put a Big Turbo on you could use this with the turbo rotated & run the compressor d/c tube under the manifold.
Any way you cut it $125 is a good price for this manifold!
OR
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
Arctic Assassian
livestrong14
