How in the world do you unplug the coilpack??
I was just wondering. because it seems like the ticking noise I hear isn't the lifters and it's the coil pack, because when I hit it, it goes away, but then comes back after a few seconds. Car could be more responsive to. Just the damn connector, she won't come undone, wanted to see if the contacts were dirty, now it seems like they are rusted solid. I tried grabbing them with two pliers and squeezed the connector. Anyone else have this issue?
Arctic Assassian
Dynamic Entry
When you get them off try putting some dialectric grease in there... it'll act as an anti-seize as well as keeping moisture away.
- Chester
- Chester
EJ22 n/a installed in 1984 Volkswagen Transporter/Vanagon/Bulli
EJ22 motor with blown head-gasket undergoing rebuild to stock specifications
92ss satinsvoice
BXSS is right. you have to pull the tap up. not press down. its a weird connector.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
94 L n/a 5spd, Rip
lol, I just realized this thanks guys. I was pulling out the rad to and said wth why won't it come out. then i looked closely with a flashlight and realized it just pulls up. Brilliant ...
IronMonkeyL255
At least they aren't like chryslers, and have a lock in the clip that you can't see because they put the connector all the way in the back attached to a 2 foot long coil pack that can't be removed until you undo that connector.......
Rio Red '91 Legacy SS
