front Axles
jchipper
front Axles
Post by jchipper »
How do I remove the front drive axles out of the Transmission? I've tried for all I'm worth and can't seem to get them out... it's a Legacy
ciper
Post by ciper »
Remove the roll pins first.
jchipper
Post by jchipper »
and those are?
ciper
Post by ciper »
The pins that go through the stubs. They are about as big around as a pencil. Turn the axle while looking at the green part near the trans and you will see what I mean
jchipper
Post by jchipper »
humm ok do I need to remove the boot?
Post by SILINC3R »
no you do not. the pin is farthest away from the tire.
ciper
Post by ciper »
Don't touch the boot. Its between the transmission and the inner boot. Just rotate the axle and you will see two holes on the green portion.
Dynamic Entry
Post by Dynamic Entry »
I was slow to post... what they said^^^^ & drive it out/through with a punch
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
The pin only comes out one way. There is a chamfer on side. The roll pin needs to be driven that side.
that explains why i had such a hard time getting the pin in on one of the axles, only put it through one side, didn't pay attention to the other.
ciper
Post by ciper »
There is a tool that works perfectly for removing them.
However who wants to spend 16$ plus shipping for a one trick pony. I posted this in another thread but another tool exists that is perfect for it and most of you already have it.
There are screw driver sets that are similar to eye glass screwdrivers. The shaft is black, the handle portion is silver metal and the top has a nut that spins freely. One of the sizes is perfect for removing roll pins because the black shaft part fits inside the pin and the shoulder is the same diameter as the outside of the pin. I wish i could find a picture to show you.
Post by SILINC3R »
or a reglular philips screw driver should work
Just pick up a good set of punches
