5 mt in nyc
bepa
5 mt in nyc
Post by bepa »
it coming out of a 94 turbo but was not a stock unit.
it is a cable operated and not what I need. will be available by weeks end.
make a good offer. and low baller offers are not answered. fair are.
be well, bepa
91 SS/ 01 MB ML 55
Bronx, NY.
bepa
up date
Post by bepa »
got this from jilo860. well you read and see who got who.
he told me he did not think I should try to drive it. so I towed it to brothers house. it's a little away but he helps out.
would not pull above 2500 rpm's. checked the alingnment of cams and crank. duh. aline everything and it starts and idles well. cruise around and check again. all sounds normal. fill up and on way.
30 minutes later and I hear the rod bearing or crank. did not make the top of the hill and it was done.
tried to call him and his phone is out of service. maybe he still reads these post. no # here. not right to go to house! or even near it. life will get him first. this car has rust, bad rims and tires.
all I was looking to get was the engine and trany for a short time.
be lucky to sell trany, rear end, SS brackets, rotors and calibers. there is good interior trim. someone has first for these
passenger side doors are good always; but spoken for
local pick up is hood missing scoop, trunk missing wing, but good lens and light on same.
mup flaps all four. good radiator, vent was added coolant resesvior on turbo models.
set of ej222t heads. sohc. more to come.
intake manifold with pink injectors, color that I see.
be well, bepa
91 SS/ 01 MB ML 55
Bronx, NY.
