I would like to buy two "parts" from your car.
First, know that area under the door where it transitions from black to body paint? I want a chunk cut out of that between two points.
Second, I would like you to cut the top off the rear strut mounts. This would essentially create two plates with three bolt holes and a large beveled center hole.
Anyone with a parts car and a sawzall?
