cutting down the clutch reservoir?
Front, Top, Air, Water.
flatoutfred
Post by flatoutfred »
Now that my wrx 06 intercooler is in place , I'm trying to figure how to move the clutch reservoir away from my i/c . This way I would have a better throttle body/intercooler alignement.
So I thought I could cut a inch or so from the the reservoir.
Anyone ever tried?
What troubles could that cause?
Legacy turbo, desnorkled, intercooled, TD04, Borla catback, urethane mounts, wrx rear brakes.
Dynamic Entry
Post by Dynamic Entry »
I did it at the suggestion of StiPro who had done it before me.
No problems at all, I cut it about an inch up from the bottom and it went back on without issue.
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
dscoobydoo
Post by dscoobydoo »
You could always source another reservoir from a Junkyard car.
Subaru made a few that are offset to the right, and lower.
I think mine was from a late 90's legacy.
That way I did not have to cut anything.
But I did have to replace it, so that was a little bit more effort.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Yeah,
I'd recommend trying to find the offset MC. Blackbart has sold them in the past.
Here's a pic.
http://www.main.experiencetherave.com/s ... es/td05/03
http://www.main.experiencetherave.com/s ... es/td05/04
flatoutfred
Thanks guys for the feedbacks, I think I'm gonna cut it like Dynamic Entry did cause I'm not convinced that an offset reservoir would clear the i/c.
I'll probably do that tonight.
flatoutfred
I've finally cut the tank 1.5 inch from the bottom and it gave me the exact space I needed to align the throttle and the i/c.
Took me 2 minutes
Still my friend who works at the subaru stealer will look for me to see if he can get an offset one.
dscoobydoo
flatoutfred wrote:Thanks guys for the feedbacks, I think I'm gonna cut it like Dynamic Entry did cause I'm not convinced that an offset reservoir would clear the i/c.
LOL- UM- Did you read my set-up?
It clears the IC.
05 GD-STI
00- GF
flatoutfred
It clears the IC.
Yeah, but I really had to install the intercooler properly since I butchered the stock throttle to turbo pipe :roll:. So I'll be waiting for the offset one.
By the way, It's now fully fonctionnal. The car I had is now a rocket (12psi).
FCD here I come! :twisted:
