Ok, so yesterday I installed wrx 2002 coil springs with kyb gr2 struts. The struts were for a 96 impreza.
In front, I used the upper spring perch and rubber isolator from a 93 impreza and all the rest was coming from my 92 ss suspension.
At the back, I used all the hardware from the stock suspension.
The ride is now stiffer and drop is 3/4 inch all around.
It took me 6 hours with a lift, an impact and a good spring compressor.
It was the first time I was doing it and it's definitely not the kind of job I would have done in the alley with a hand jack.
wrx coil springs installed
flatoutfred
Legacy turbo, desnorkled, intercooled, TD04, Borla catback, urethane mounts, wrx rear brakes.
