94 Legacy 2.2L Turbo (Ej22T) Speedometer Cable or Senor?
Impreza2.2T
Post by Impreza2.2T »
Does anybody know if this tranny has a speedometer sensor or cable ? and if it would fit into a Impreza gauge cluster.
PhyrraM
Post by PhyrraM »
Cable.
I believe that the trans will accept a sensor in place of a cable if your chassis needs it that way.
ciper
Re: 94 Legacy 2.2L Turbo (Ej22T) Speedometer Cable or Senor?
Post by ciper »
Impreza2.2T wrote:Does anybody know if this tranny has a speedometer sensor or cable ? and if it would fit into a Impreza gauge cluster.
Your question is confusing and lacks detail. Which Impreza are you talking about? Imprezas have used both cable and electronic speedo drives. Either way the transmissions can accept either type.
Impreza2.2T
No, no no, its a legacy 94 all wheel drive thats turbo charged. It some how has a Auto cluster right now that only show my RPMS.
ciper
Post by ciper »
This is hard to explain but I have an idea of why its not working.
On the trans is something screwed into it. The speedo cable snaps into this thing. Inside of this thing there is a short metal shaft. I bet that shaft is broken.
BSOD2600
Post by BSOD2600 »
When I installed my new speedo cable, I was dumb and didn't attach that U shapped clip properly between the speedocable and the short cable coming out of the tranny. While it all looked good and snug, the cable didn't actually connect internally at that joint... Just something to think about and check too.
'11 WRX Limited
'94 TW | R.I.P.
