AMR ENGINEERING COILOVER GROUP BUY NOW ON! ENDING SOON!!!
Locked
AMR Engineering
Post by AMR Engineering »
I'd like to introduce to you our new line of coilover system. Now you may ask yourself, what is so different about our coilovers. Well first off we offer a Lifetime warranty. Were one of the few companies that even offer such a warranty. Next we only and strictly do custom applications. Standard rates, off the shelf rates don't exist in our business. You really can't expect that a standard off the shelf rate is going to meet the needs of every person out there. Why spend 700+ bux of your hard earned money and be one of those people posting in the suspension forum that your so called brand X coilover is either too soft, bouncy, or etc. Then you will see post about brand X coilover being underdamped or produced for street cars, but don't even come close to the ride quality that you are looking for. Especially with all these companies popping out of no where offering you the same spring rates and valving, but have a different color or name on it. One of the most important things many of you are looking for is ride quality. A lot of you spend hours and hours researching on what spring rates or coilover is going to meet your needs. But comparing spring rates from one manuf. to another isn't going to work because of the fact each manuf. has their own way of valving/matchin their coilover systems. Well were here to educate you as well as help you determine what is the best setup for you. AMR Engineering is not a huge company so we can spend the extra time with our customers and be a lil more hands on with the products we produce. We have hours and hours of testing and experience with our coilovers in every chassis and application we offer. Basically no more guessing games, were the real deal. We run what we sell, and know how our coilovers are going to work in a variety of different combinations. Now with that said, let's give you some specs.
-8 way rebound and compression adjusability
-Corrosion and rust resistant
-46mm piston
-Seperate Height and Preload adjustment
-Mono-Tube design rather than Twin-Tube
-Customized for each application
WE DO NOT OFFER OFF THE SHELF RATES!! OFF THE SHELF RATES DO NOT EXIST TO US NOR DO WE BELIEVE IN THEM. EACH SETUP IS CUSTOMIZED AND MADE FOR EACH SPECIFIC CUSTOMERS CAR AND NEEDS! I CAN'T MAKE THAT ANY CLEARER.
Group buy list now starting! I only need 5 people to get this going everyone!
1)
2)
3)
4)
5)
Let's make this happen!
We still remember you.
Go away!
Locked
