T-Bird Mod?
Posted: Sun Jul 06, 2008 7:27 pm
by Tommio RS
Well I have been looking all over the boards here and i cant seem to get a good answer about this mod!
Does it increase cfm?
Does it increase power?
All i know is that it gives you crazy fast spooling over stock and hold 15ish psi.
Thanks!
Posted: Mon Jul 07, 2008 10:23 pm
by dzx
Stock should already have crazy fast spool. If you're looking for power, the vf-11 is going to be very limited no matter what you do.
Re: T-Bird Mod?
Posted: Tue Jul 08, 2008 7:39 am
by 555BCTurbo
Thanks!
You answered your own question...the VF11 won't hold 15 psi to redline...whereas my T-bird Inbred would...
Posted: Tue Jul 08, 2008 2:28 pm
by dscoobydoo
Just find a good used TD04. Problem solved! Or Go even bigger!
Posted: Tue Jul 08, 2008 3:29 pm
by BXSS
+1 much easier to just slap on a td04.
Posted: Tue Jul 08, 2008 4:39 pm
by Legacy Rally Guy
+1 my TD04 & intercooler wasn't bad at all.
and it pulls nicely! with the smallest amount of lag.
Posted: Wed Jul 09, 2008 4:03 am
by Tommio RS
Very interesting. But the TD04 is not much of a gain. Now if i could get me hands on a VF39, Thats a gain! But then i would need some injectors.... would a set of 02-03 wrx injectors work in my Legacy turbo?
Posted: Thu Jul 10, 2008 5:39 am
by Arctic Assassian
no but if you get 92-94 legacy n/a fuel rails they will.
Posted: Thu Jul 10, 2008 6:25 am
by 555BCTurbo
Arctic Assassian wrote:no but if you get 92-94 legacy n/a fuel rails they will.
Incorrect...WRX injectors are top feed...Legacys have sidefeed
Posted: Thu Jul 10, 2008 7:35 pm
by Tommio RS
ok side feed is what i need.
Posted: Sun Jul 13, 2008 12:54 am
by PhilSine
04 and up STi injectors are 550cc and sidefeed. They will work.
Posted: Sun Jul 13, 2008 1:28 am
by 555BCTurbo
PhilSine wrote:04 and up STi injectors are 550cc and sidefeed. They will work.
But you will need to run some sort of engine management modifications...as the stock ECU cannot effectively trim 550s
Posted: Sun Jul 13, 2008 3:13 am
by PhilSine
Well by work I meant plug in and flow but you're right, they won't flow right unless you have a way to control them.
On that note, since I am new to EJ22t's, can any larger injectors be dropped in and the factory ECU run them?
Posted: Sun Jul 13, 2008 4:32 am
by dscoobydoo
PhilSine wrote:Well by work I meant plug in and flow but you're right, they won't flow right unless you have a way to control them.
What do you mean? Some people here have managed to go with 440's and say a VF turbo on 12-15 lbs and the stock computer works, but not great. But anything bigger than that, will require some form of add-on or alternate ECU.
Posted: Sun Jul 13, 2008 6:18 am
by PhilSine
WOuld a TD04 be slightly better suited for 440's since it was what the WRX's had for a combo or does the VF11 keep up with CFM demands when you turn it up?
My only experience with injectors and all has come from adding the turbo to my 98 OBS where any variance from factory confuses the ECU. I run an E-Manage Ultimate in that car to make it run right.
Posted: Mon Jul 14, 2008 3:30 am
by 93forestpearl
Swapping injectors to match the turbo based on the factory fueling is foolish. It will run, but poorly. These things will idle below 12.0:1, not that you'd want to.
Playing games like this without any kind of testing (WBO2) is asking for trouble, or wasting a lot of gas.
Widebands are cheap and should be the first thing anyone buys when playing with stuff like this.
