Ok. One (possibly a few) of the lifters on the driver's side of my engine are clattering like crazy. I've used Seafoam and it cleared up the noise for a day and then it came right back.
This isn't the first time this has happened either.
So now here's the n00b question: To replace the lifters, do I need to pull the head off or can I just pop off the rocker arm assembly and easily swap them out?
n00b status question
Ya you can get them out without taking the head off, or even taking the cams out. Take the rocker cover off, and there's a few bolts that take the whole assembly off. I recommend having an in-lb wrench handy for re-assembly.
The Haynes manual or FSM that's floating around is useful as well.
Part 2:
So it's been three days since I changed out all of the lifters with brand new ones. Everything was great...
....driving home tonight and the problem started up again. What the hell is causing one of the lifters to go dead?!
