I'd like to know where to find the G-Sensor in a '91 Legacy SS 5MT. I know that it should be somewhere under the hood, but I don't know where exactly it's located. It would be great if someone could point me in the right direction.
Here's a picture of it that I found on an auction site:
My ABS unit is throwing "code 16", which according to this FSM:
http://www.main.experiencetherave.com/s ... bsdiag.jpg
and this post:
http://bbs.legacycentral.org/viewtopic. ... ht=gsensor
is:
16 - G-sensor or other unidentified problem
I figure that the G-Sensor in my Leggie is either disconnected, or toast. If that doesn't turn out to be a problem, then what else could be causing ABS Code 16 to show up?
Thanks,
P.
