Hey there, I just picked up a '92 Legacy SS Auto yesterday, and it refuses to shift into 2nd gear until I hit 20mph, even at really low throttle. It's at about 3100-3300rpm when it finally shifts. Is this normal? Something is telling me no, because it just doesn't feel right.
Also, it seems to hesitate/stumble when I give it a lot of throttle going up a hill, or off-the-line. It's not horrible, but it is annoying.
Any ideas?
Thanks,
Andrew
Not Shifting Into 2nd Until 20mph & Hesitation Problems
Have you checked the trans fluid?
You may be low on fluid, or the fluid may need changed.
Re: Not Shifting Into 2nd Until 20mph & Hesitation Problems
Hi there I'm having the same problems as you are! Mine is a 93 ss 4eat does it hesitate when you tromp on it?? If I find out anything I'll let you know cause your not the only one who's havin these issues.
