EGT Gauge, Pyrometer Probe location??
Where should i mount the EGT Probe?
Mount it in the Uppipe!!!
1
14%
Mount it in the Downpipe!!!!
1
14%
Mount it up yer $@%& !!!!!!
0
No votes
What the Crapzilla is an EGT Probe, sounds dirty...
0
No votes
How about mounting it in the headers!?
5
71%
Total votes: 7
NuclearBacon
Post by NuclearBacon »
So now that i'm finally putting on some mods i bought a while back, i want to get my Exhaust Gas Temp Gauge mounted in my A pillar, and get the probe mounted.
I've read about both places to put it, Up-pipe, and the Downpipe... and ive heard that if you place it in the up-pipe, you'll get a great reading, but if something lets go, there goes your turbo... then people say that in the downpipe, you dont get a true reading...
i'll have to take either piece down to "my" muffler shop (Minute Muffler in Dublin, Ca) and they'll weld in a bung for the probe... but where oh where shall i mount it????
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
NuclearBacon
no one wants to vote eh?
-Luigi-
asc_up
Post by asc_up »
I've always heard to mount it in the headers right before the up-pipe.
NuclearBacon
ooo interesting.... in the headers eh?? 'll add that to the vote ;)
-Luigi-
You need to mount it in the headers. Anywhere else really isn't going to do you any good.
There's a spot on the passenger header where you can drill & tap. You can kind of see the spot in this pic
http://www.main.experiencetherave.com/s ... P_5245.JPG
dscoobydoo
Post by dscoobydoo »
Legacy777 wrote:You need to mount it in the headers. Anywhere else really isn't going to do you any good.
Second that- it is where mine is. The EGT is supposed to measure the gas right out of the exhaust port. The further down you put it, the less accurate your reading is.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
NuclearBacon
Excellent. Thank you for clearing this up!
-Luigi-
scuzzy
Post by scuzzy »
and #3 (right at that spot I believe) runs hottest AFAIK.
#82 M4 TRSCCA Rallycross
NuclearBacon
could i put a wideband o2 sensor close by in the same piece of pipe? or would it need to be further down the line...
-Luigi-
dscoobydoo
I think 02 needs to be a bit further down where all of the gasses have merged.
Most people put it in the top of the downpipe.
05 GD-STI
00- GF
NuclearBacon
ok, so close by the original o2 sensor.... figures ;)
-Luigi-
PhilSine
Post by PhilSine »
I selected downpipe by mistake :P
My question is why not the up pipe where the OE WRX EGT probe location is?
91 Legacy SS
98 OBS-T
legacy92ej22t
Post by legacy92ej22t »
scuzzy wrote:and #3 (right at that spot I believe) runs hottest AFAIK.
Personally, I'd put in on the #4 manifold. Most EJ22T failures I've seen lately have been #4, not #3 even though that is the fabled hot spot because of the turbo. #4 doesn't get as much coolant flow for some reason which is why they tend to go "pop".
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
93Leg-c
Post by 93Leg-c »
legacy92ej22t wrote:Personally, I'd put in on the #4 manifold. Most EJ22T failures I've seen lately have been #4, not #3 even though that is the fabled hot spot because of the turbo. #4 doesn't get as much coolant flow for some reason which is why they tend to go "pop".
I agree. I've lost two turbo engines because the #4 exhaust valves burned.
Probably the easiest way to check your engine is pull the spark plugs. The porcelain around the center electrodes on my #4 plugs were super white -- indicative of super hot temps.
'94 TW
GTEASER
Re: EGT Gauge, Pyrometer Probe location??
Post by GTEASER »
Bump from the long long ago....
Josh, I am not seeing where in the header you recommend the EGT probe to go. Additionally, any more direction on the location at #4?
Install it in the up-pipe.
More pics
http://main.experiencetherave.com/subar ... xhcoating/
