Have another 20 sets of braces being made for West Coast Subaru Show. I am offering them to you first at the same show price! Let's get some of these babies installed!
http://www.simplysubie.com/Performance.html
![Image](http://i55.photobucket.com/albums/g155/Livestrong14/DSC00537.jpg)
What do they do?
They tie the lower a-pillar subframe to the upper front frame member to provide tiangulation of the junction between the two. The stock braces are made of stamped steel and can be bent over your thigh. These braces are a one of a kind solid aluminum piece. There is no comparison.
What are they made of?
6061 T6 Aluminum plate
What are the benefits?
After installing these you can feel a great improvement in front end stability for such a small part. Instead of having the chassis absorb the shock, let your shocks and springs do it! After all that's what they're there for.
Turn in is improved, steering response is better, and the overall point and shoot method of driving the car is improved. I love this mod.
Tools Needed For Installation:
Flat head screwdriver
Needlenose pliers
Phillips screwdriver
10mm socket with extension
14mm socket with extension
3/8" drive rachet
![Image](http://i55.photobucket.com/albums/g155/Livestrong14/100_0406.jpg)
What do they fit?
90-94 Legacy Sedans and Wagons
02-07 WRX Sedans and Wagons
99+ RS Models
98+ Forester Models
04-07 STi Models
SOME 93-01 Impreza L models will require two holes to be drilled and tapped.
How much are they?
Special WCSS offer of $79. Normal retail value of 99.99
Each set comes with new Grade 8 bolts and washers, aswell as installation guide.
Available in two finishes.
1. Polished Aluminum
2. Royal Sports Blue
Order yours today! Will have them boxed up, ready to ship or pick up by August 12th!
Paypal or credit card accepted pm for more information
