this is the 90* elbow between the intake resonator and the turbo inlet that has the bpv blowing into it along with a couple other pipes
i also need the little c shaped hose coming right off the pcv valve
mine are all cracked and almost unusable
i need them shipped to ottawa ontario canada
25-2415 southvale cres
K1B 4T9
thanks
-Alex
wtb: 90* turbo intake elbow
mexicanzero
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
NuclearBacon
I sourced a few, and they all turned out to be cracked and unusuable. board members were offering me the 90 degree inlet for about 40 to 50 bucks... i had to go to the Stealership, and i got one out the door for $88.00. Here is the link where you can order on online for the same price. my local dealer just matched the online price.....
http://www.graphics.cornell.edu/~v/vacuum/ej22t_pcv.gif
https://www.1stsubaruparts.com/part_number.html
I ordered one and the rubber is super soft and malluable, easy to connect. I know its a hunk of change.. but i'll never have to buy another one again. Hope this helps
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
mexicanzero
wow! that site is pretty cool i think i might get a new one ur right that all the ones on cars from the early 90's will probably be cracked...
and i really thought that one elbow would be like over 100$ on its own but its 69$.
thanks again
-Alex
thanks again
-Alex
