http://i28.photobucket.com/albums/c214/ ... 1/TMIC.jpg
That be my intercooler. So it looks like im going to have to run a y pipe off those two holes pictured, to the turbo output. Then i connect the large output to the throttle body. The other hole on the other side is something to do with a BOV, can someone explain that more ? So heres the questions.
As far as i know i only have to relocate coolant tank, and cut down the clutch res. I just physically cut down the clutch fluid res ? And coolant tank relocate, is there a certain height it has to stay at or anything special, or can it just go anywhere ?
For piping kit, which one should i buy ?
I found this site :http://store.racing-solutions.org/
They have make it yourself kits, which one should i get ? Well, the better question is that diameter piping is required, and what bends do i need. Also, where can i buy the Y pipe ? thanks for the help !
installing 06/07 wrx intercooler
I'm still fighting with my install...
As for the two holes... Your gonna want to find the actual elbows that come off of them...
It appears that on my car I can have the IC rest on the clutch resevoir.... which it would be better to have the offset on however it appears like it will work...
I'm also using a vf10 turbo, which changes things a little bit...
I would suggest reading SubaruNations posts regarding the install.... he has a lot of good do's and don'ts for the installation.
flatoutfred
I've cut my clutch res a inch and a half and there is no problem at all. For the y pipe I've modified the stock one but it could be better, I'll buy one like this ebay link
and buy a 45 degree silicone hose or a prestone hose that fits. For the bybass valve I've bought a adapter flange like this on ebay
Good luck
Good luck
Legacy turbo, desnorkled, intercooled, TD04, Borla catback, urethane mounts, wrx rear brakes.
Its the little awkward shaped outlet thingy that goes on the drivers side front of the intercooler.... triangular bracket is the best description.
The little triangle thingy is called a recirculator valve. Its job is to vent excess pressure out of the intercooler when you let off the gas. The intent of the recirc valve is to recirculate that excess pressure back into the intake. If you look on an OE WRX intercooler setup you'll see that the recirc valve vents the excess pressure back into the intake before the turbo but after the IACV line.
91 Legacy SS
98 OBS-T
98 OBS-T
you're going to want a BPV not a BOV otherwise your car will be in not good shape after awhile.
flat out fred: ya that recirc plate works, it's what im using.
feel free to read my build thread and check out my gallery for ALOT of pictures on how to do this
