I am wanting to get the city lights working on my 91edm lights. I have been looking for the counterpart to the connector as I really don't want to cut and splice. What has everyone else done? Is there a counterpart to that connector on any of the usdm cars? Thanks for any help.
Jeff
Hooking up the city lights
ultrasonic
We don't have DRL on the USDM cars.
My plan is to cut off the odd connector on the city light, it doesn't match up with anything I've been able to locate anyway.
Then, hit a salvage yard and get the proper connectors to mate with the existing parking lamps in your car. The trick is to get both the male and female connectors, and leave plenty of wire length when you cut them from the donor harness. That's four total connectors-- two male, two female. One each for left and right.
Then splice one male and one female on to the city light wires in parallel with each other.
Now, all you have to do is disconnect the parking lamp connector from the chassis harness and connect both chassis and lamp connectors to the appropriate male and female connectors on the city light. That's plug and play-- no harm no foul on your stock wiring harness. Easy to remove if you sell the EDM headlights.
If I'm not mistaken the harness connectors are the same on the turn signals, so you could also try running the city lights along with your turn signals.
Here is a diagram of what I'm talking about. Let me know if it's not clear. Click to enlarge.
Also, here are images of the two pole connector that is on the parking lamp and the turn signals on my 1991 SS. I think they went to a different connector in MY92
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
03 Legacy L Wagon
Steve that will work. I lucked out and had the connectors for mine I believe. I just tapped into the parking lights for my power.
on my 90 edm lights it was one of those t conecters so i cut another out of a old harness and wired to my corner lights
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White
93BC"edm" 93GC 90BC R.I.P.
