Adding cruise control
rrhartjr
Post by rrhartjr »
I have a 1992 Legacy NA auto. It does not have cruise control.
Can I add it? What parts do I need?
They actually made a kithttp://bbs.legacycentral.org/viewtopic.php?t=36650
If you want to add it, you'll need the cruise vacuum pump, actuator and throttle cable, brake switch, cruise clutch switch if manual, and the cruise computer, cruise set stalk, and on/off button. Those are the main things. I'm making the assumption the car is pre-wired, so all you need to do is hook things up. But you'd want to conffirm that.
