Page 1 of 2
TD04 + TMIC + custom pipes = complete kit!
Posted: Mon Aug 04, 2008 7:31 pm
by Binford
Check it out:
http://i39.photobucket.com/albums/e174/ ... 000151.jpg
Complete kit including:
TD04
WRX TMIC
MBC
custom steel intake pipe
rubber 90* boot
custom steel y-pipe
rubber throttle body hose
custom steel BOV flange
Note: TMIC not that shiny anymore.
Everything is in excellent working order and currently installed. I'm looking for $300 for the complete kit. Thanks.
Also have TurboXS FCD I'll throw in for another $50, or will sell seperate for $75. All prices plus shipping.
Posted: Tue Aug 05, 2008 7:38 am
by 94SS_Canada
good deal for someone with no time!
Posted: Wed Aug 06, 2008 5:12 pm
by Binford
Still available!
Posted: Wed Aug 06, 2008 7:23 pm
by Dusty B
I'd probably snag this if I hadn't just picked up a ported/polished tdo4. It'd still be worth buying, but I'm kind of against the smashing of firewall/cutting of tb. Good luck with sale. nice to see a whole kit for someone!
Posted: Thu Aug 07, 2008 3:27 am
by Binford
Dusty B wrote:I'd probably snag this if I hadn't just picked up a ported/polished tdo4. It'd still be worth buying, but I'm kind of against the smashing of firewall/cutting of tb. Good luck with sale. nice to see a whole kit for someone!
Thanks for reminding me Dusty B! I have modified this TMIC so there is no cutting of the throttle body necessary!
Posted: Thu Aug 07, 2008 3:35 am
by greg donovan
man i wish i had some extra cash for this set up.
would there need to be changes made to the fuel system if the FCD was used and the boost cranked up the optimal setting for the tdo4?
OT, would you drive up to fargo for a rallycross in mid oct if it fit your schedule?
Posted: Thu Aug 07, 2008 3:43 am
by Binford
I ran 16-18 psi with this setup on my SS, which I'd say is on the "high" side of optimal
with the only "fuel system mod" being a Walbro. This setup is currently on my wagon running ~12 psi on N/A ECU, turbo injectors, and the Walbro.
Posted: Thu Aug 07, 2008 3:46 am
by Binford
greg donovan wrote:OT, would you drive up to fargo for a rallycross in mid oct if it fit your schedule?
As a spectator, hell yeah! As a competitor, I have nothing to drive like that. My wagon is undergoing an "offroad" transformation!
Posted: Thu Aug 07, 2008 4:49 am
by greg donovan
Binford wrote:greg donovan wrote:OT, would you drive up to fargo for a rallycross in mid oct if it fit your schedule?
you going for the rockcrawler look now?
Posted: Thu Aug 07, 2008 6:18 am
by Binford
More or less.
Tubular sub-structures.......
And it's not for the looks, purely functional.
Posted: Thu Aug 07, 2008 1:25 pm
by greg donovan
Binford wrote:More or less.
function over form is the way to go.
i would love to be pusing 12 pounds of boost right now.
Posted: Thu Aug 07, 2008 6:46 pm
by n2x4
did you block off the PCV valve??
Posted: Thu Aug 07, 2008 7:15 pm
by Binford
n2x4 wrote:did you block off the PCV valve??
Yes I did.
Posted: Mon Aug 11, 2008 2:01 pm
by Spitfire999
Would you be willing to separate anything form this kit?
Ben
Posted: Mon Aug 11, 2008 7:32 pm
by Binford
Spitfire999 wrote:Would you be willing to separate anything form this kit?
Ben
Depends on what it is, as this is tenitively pending......
Posted: Mon Aug 11, 2008 7:40 pm
by Spitfire999
Looking for everything except the turbo and the intercooler.
Posted: Mon Aug 11, 2008 8:13 pm
by Binford
I could probably make up some more of the custom piping........
Posted: Mon Aug 11, 2008 8:54 pm
by Spitfire999
If you could make another 90 degree bend from the turbo and then that pipe that goes from that to the air box, I would be interested.
Ben
Posted: Mon Aug 11, 2008 9:32 pm
by Binford
Spitfire999 wrote:If you could make another 90 degree bend from the turbo and then that pipe that goes from that to the air box, I would be interested.
Ben
The 90 degree piece is a rubber hose, but the "intake" pipe I could duplicate. You'd need to tell me what size nipples, how many, and where to put them. It's been a long time since I've seen a stock setup, and I know I deleted some of those hoses on mine. I could go so far as to get the rubber 90 for you if you chose. Let me know what you need and I could shoot you a price based on that.
Would anyone else be interested?
Posted: Tue Aug 12, 2008 2:39 am
by dkopp
Binford wrote:Spitfire999 wrote:If you could make another 90 degree bend from the turbo and then that pipe that goes from that to the air box, I would be interested.
Ben
+1 for the custom steel turbo, I/C and block-off piping. And, if you're buying 90* elbows, i'd be in for that too.
Posted: Tue Aug 12, 2008 3:09 pm
by Spitfire999
Yeah, I'll be doing some work on my car tonight (just shit coolant all over my driveway, I hope its just a hose gone bad
), so ill let you know the nipple sizes/how many. But you should possibly start a separate thread, I would think there would be a big demand if you want to make a bunch.
Posted: Tue Aug 12, 2008 5:37 pm
by Binford
Forgot to post it here, I did start a new thread:
http://bbs.legacycentral.org/viewtopic.php?t=36928
Posted: Mon Aug 18, 2008 4:55 am
by wtdash
Sold?
Posted: Mon Aug 18, 2008 7:14 pm
by Binford
wtdash wrote:Sold?
Nope, still available.
Posted: Mon Aug 18, 2008 8:54 pm
by wtdash
So does the firewall need 'massaged'? Or does the modded TMIC take care of that too?
What's the good/bad of blocking off the PCV? Will it throw a CEL?
