So, What do y'all think?
86ruguy
Post by 86ruguy »
92wagon (wife's)
92 sedan (sold)
91 ss no mods (sold)
88 GL Wagon (broken)
94SS_Canada
Post by 94SS_Canada »
looks good, whered you get the fogs?
Can i see the switch you have wired up for turning them on?
FastRust
impreza_GC8
Post by impreza_GC8 »
I'd say keep the high setup. I always cringe when I see big lights down low on cars that are set up for less than ideal road conditions. All it would take is one rock or a dirt crest to eliminate those lower lights from the picture. Up high fits the rally style of the first gen Leg a bit more IMO. After all, they did carry the SWRT until the Impreza came around.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
86ruguy
Post by 86ruguy »
Thanks. I got the fog lights at 4WHEEL Parts for like $90.00. Got the driving lights at SHUCKS AUTO PARTS for $75.00
92wagon (wife's)
92 sedan (sold)
NuclearBacon
Post by NuclearBacon »
do they bounce at all when you're driving? how did you mount them? it looks like each light is individually mounted?
somoene should make a bar that goes right where yours does and mass product the things!!! i'd buy one....
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
smh0101
Post by smh0101 »
hehe... i also spy a little hoodscoop in the after pic to... lol
86ruguy
Post by 86ruguy »
NuclearBacon wrote:do they bounce at all when you're driving? how did you mount them? it looks like each light is individually mounted?
No they don't bounce. I took out the grille and drilled four 17/32" holes all the way thru the bumper beam and used 3/8" bolts and lock nuts.
And YES Spencer, there is a little hood scoop. Got the hood from beatersubi (Stephan) for a REALLY good price. AND put a deposit on my SS bumper.
92wagon (wife's)
92 sedan (sold)
You need a turbo grille, is what I think :wink: .
Seriously though, they look, and prolly work, better up high.
86ruguy
Post by 86ruguy »
At this point there is NOOOOOO room for a grill. Maybe if someone would help me make some brackets I would put a grill back in. (hint, hint)
92wagon (wife's)
92 sedan (sold)
Fogs actually work better down low as they're designed to cut under the fog and wide. But I had mine mounted in a similar manner, for the same reason of protection, and they still worked well. Look better, too.
86ruguy
Post by 86ruguy »
Yeah, I really like it a lot. Thanks for the Props tho.
92wagon (wife's)
92 sedan (sold)
86ruguy
Post by 86ruguy »
I gave her a bath. Now she feels SEXYYYYYY!!!!!!!!!!!!!!!!!
http://s203.photobucket.com/albums/aa12 ... 19034f.pbw
92wagon (wife's)
92 sedan (sold)
