New member with a '97 Turbo outback
impreza_GC8
Post by impreza_GC8 »
Went up to Des Moines, IA last weekend and purchased this vehicle from a fellow NASIOC'er. It is quite the vehicle to say the least and it deserves its nickname of "Frankenstine." On to the pics!
A decent pic that shows the white hatch and red door.
Notice anything "different" about whats under the hood scoop?
1997 Subaru Outback
5 speed, 4.11 with LSD
Mods:
EJ22T ECU & wiring harness
EJ22T crank & rods
EJ25 (NA) block halves.
EJ25 DOHC heads ('96 with hydro adjusters)
EJ25 flat top pistons
EJ20G intake manifold
440cc injectors
VF8 turbo (JDM ej20g)
catless 3" bellmouth downpipe
EJ22T exhaust
EJ22T fuel pump (have Walbro 255 in a box)
2002 WRX top mount IC with custom IC y-pipe
TurboXS adjustable bypass valve
comes in around 2.4 liters with around 8:1 compression ratio
Exterior:
white hatch and quarter panel with red driver's door
JDM Legacy front grill
Interior:
Prosport Oil Pressure, Boost, and EGT guages in lower DIN slot
aftermarket head unit
The car needs to be tuned but OBD1 is somewhat limiting my tuning abilities. If anyone has any recommendations I will gladly listen.
Here is my other car:
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
94SS_Canada
Post by 94SS_Canada »
Sweet, What are the numbers on that thing?
You need a matching hatch!
And a good clean!
Aerotech
Post by Aerotech »
Not much can be done as far as ECU tuning, other than running a piggyback (PerfectPower 6) or standalone ECU... Haltech 8 is a plug n play when ordered for the Subaru.
Nice assembleage of parts ya got there 8) Take it further with mismatched wheels....
I've seen a few really nice monochromatic Outbacks, they lend themselves nicely to that type of paint.
Have fun!
Jerry
SubOnno
Post by SubOnno »
Is this car tuned for Torque instead of HP looking at the specs?
Looks pretty cool by the way! Who would expect an outback with a red door and white rear to be quick ?
Subaru Legacy MY94 2.0 AWD
94SS_Canada
oh god its got a red door too, hehe didnt even notice
FastRust
Is that car originally from the NW? I think I recall seeing it on craigslist here.
Either way, quite the sleeper! :smt023
impreza_GC8
Aerotech wrote:Not much can be done as far as ECU tuning, other than running a piggyback (PerfectPower 6) or standalone ECU... Haltech 8 is a plug n play when ordered for the Subaru.
Isn't PP6 meant for OBD2? This car is running the OBD1 EJ22T ECU and harness so I need OBD1 options. I am def open to a PP6 though.
SubOnno wrote:Is this car tuned for Torque instead of HP looking at the specs?
IDK, "tuned" isn't the greatest term to use because the car isn't "tuned" at all, it needs to be but OBD1 sucks. It it build to be a budget sleeper using some good parts from various Subarus. Honestly my RS feels more torquey than the Outback in the lower rpm ranges except for high end when the turbo is fully spooled and pulling. The Outback has way more grunt on the highway as well.
beatersubi wrote:Is that car originally from the NW? I think I recall seeing it on craigslist here.
It is from Des Moines, IA. It was on Craigslist there for a long long time.
jake15
Post by jake15 »
Yep, that OB was created in tacoma :D
impreza_GC8
^^^ Yes it has a Washington rebuild sticker. Do you know the person who build it perhaps? I would like to talk with him and ask some questions.
