Stumped, No spark
Posted: Fri Aug 08, 2008 10:58 am
by JabberWalkie
I have a 1990 Legacy and I am having some trouble getting it started. The problem first arose when I was trying to get my ABS error codes via some sketchy information on the intertubes. There was some smoke, so I defiantly shorted something out. Now, I am not getting any spark. In a flash of stupidity I jumped these two cables together:
This may not be the cause of the problem, but this is what I have checked/done so far. I have checked the resistances on the ignition coil, i have replaced the igniter and the ECU (that was a quite a pain). Checked battery voltage (of course). And I have checked the ignition relays. I have no clue why it is not sparking....Help!!!
Posted: Fri Aug 08, 2008 1:07 pm
by 93forestpearl
If you aren't getting a trigger signal (cam and crank) you will get no spark.
Posted: Sun Aug 10, 2008 9:20 pm
Have you checked all your fuses?
If you connected that pin to the yellow connector, you may have fried something in the ECU.
Posted: Sat Aug 30, 2008 9:01 am
by JabberWalkie
So, I checked the fuses again....lo and be hold a 30 amp has been burnt out.......replaced it and it started!..thanks guys!
